Attached file with UTF-8 coded name is not displayed nor saved correctly.
Screenshot:
For example, Thunderbird decodes the file name as expected:
Screenshot:
This issue was reported a number of times. The one I was specifically looking for I cannot find, but there is another at https://forum.emclient.com/emclient/topics/wrong-encoding-in-the-name-of-the-russian-attachment. Unfortunately there was no resolution on any of them that I can remember.
Marko, if you have a Pro License, please open a support ticket. They will be able to assist you further.
So - you need to be a paying user to report a bug? Otherwise it is ignored?
Anyone can report a bug, but if you want support from eM Client Inc. you will need a Pro License. Support options were clearly defined in the license agreement which you accepted when registering the Free License.
