Thanks for the info on rules. I notice I can define my own rule that tests on a header’s value. Alas, I’m not sure the included Spam rule or one that I define will work at Hotmail. I had a false positive where an e-mail got moved into the Junk folder (on the server). I looked as the message source. While there were some headers showing Microsoft’s spam handling, there really was no header that acted like a red/green flag or rating on spam.
I haven’t investigate their spam-related headers. Of the 3 they add, maybe 1 indicates the message was moved to the Junk folder due to their Forefront’s spam rating, which is:
X-Microsoft-Antispam-Mailbox-Delivery: abwl:0;wl:0;pcwl:0;kl:0;iwl:0;dwl:0;dkl:0;rwl:0;ucf:0;jmr:0;ex:0;auth:1;dest:J;OFR:SpamFilterAuthJ;ENG:(5062000261)(5061607266)(5061608174)(4900115)(4920090)(6375004)(4950130)(4990090)(9140004);RF:JunkEmail;
However, unless em Client supports regex (regular expressions), how could I define a rule inside of em Client to parse that header? In regex, I could use:
(?-s)^X-Microsoft-Antispam-Mailbox-Delivery: \S*RF:JunkEmail
where (?-s) means to scan to the end of the line and not further (to prevent the greedy rule from going past the header section and matching on a string in the body of the message), ^ means to anchor the string to column 1 (all headers must start in column 1), include that header name with a colon and a space (required to delimit header from its value), and series of optional non-space characters, and look for “RF: JunkEmail” somewhere in the header’s value.
However, that only tells me the message got moved into the Junk folder. em Client doesn’t need spam filtering for that since the server already moved the message into the Junk folder and em Client would retrieve the message in that folder. I don’t see anything in Hotmail’s headers for received e-mail that shows the message is spammy. If Microsoft thinks it is spammy, well, it’s going to move it into the Junk folder. Don’t need a client-side rule for that.
em Client won’t let me edit its Spam rule to see on what it tests. Most servers, if they suspect a message as spam, are going to move it into the Junk folder (on the server). So, em Client is just going to reflect the same when it syncs with the server: that the suspect e-mail already got moved into the Junk folder. The only purpose the client-side Spam rule could have is if the server rates the spamminess of a message but does NOT move it into the Junk folder. Don’t remember ever using an e-mail provider whose server’s spam filter rates a message as spam but doesn’t move it into the server-side Junk folder. Maybe that might be what happens with POP access since that only understands the concept of a mailbox (POP doesn’t understand or have any commands for folder management).
Thanks for pointing out the safe sender whitelist has nothing to do with any spam filtering inside of em Client (assuming the Spam rule doesn’t use that whitelist).
