Mick
1
Since updating to “5.0.17263.0”, some of my notification popups are coming through blank.
It appears to be any emails which are moved to sub-folders by rules, as I still get text on the notification popup for emails sent to my inbox.
I’ve included a screenshot below if that helps.
Mick
2
After trying to find a solution myself, I have noticed that “Skip Notification” is enabled in all of the rules which are giving this blank pop up.
tombam
3
Hello.
Thank you very much for reporting, it has been fixed.
Hello, i have the same problem! How to fix it?
tombam
5
Hello. It will be fixed in the next version which will be released in a few days
Thank you very much for the quick reply! Looking forward to it… Great software btw!
