Gebruik sinds kort EmCLient en ziet er goed uit. Bij het importeren van mijn outlook mappen is er ergens iets niet goed gegaan. Ik moest de mappen lokaal zetten omdat ik anders over de mailquota heen ging.
Sinds ontstaan er bij elke synchronisatie vreemde mappen met namen als 8e12e7d9-43b2-4942-a3bb-eb1c2a6b3890 en 2cae64e1-768f-4880-a36b-5bf34220b322.
Als ik ze verwijder, verschijnen ze weer na sync. Er zit geen content in de mappen.
Hi, I’m unfortunately not completely sure what you’re referring to, if you’re having issues with the outlook import feature, please make sure to make a screenshot of all errors thrown by the application or of the issue in eM Client.
Also please check the version of eM Client you currently have installed on your computer, please check the exact version number in Help > About? What mail service are you using with eM Client?
Thanks for your reply. Let me give some more info:
I was using Outlook.com online and as desktop program the Windows Mail app.
My email addresses were an send/receive alias for Outlook.com; all my folders were under the outlook.com address. I separated the two mail address again, as I was not happy with the way it worked.
I installed both email addresses as accounts in eM, the outlook.com address and the [email protected] address. I then moved the folders from to Outlook.com to the local folders in eM and I removed the outlook.com account and continued to work with the [email protected] account and the local folders.
Ever since strange folder appear under [email protected]. So I wonder why.
Hi, can you please try to navigate to Tools > Settings > Advanced, and enable AirSync logging for the problematic account?
Save the settings
Restart the application
Replicate the issue
Once the error reoccurs, please go back to the advanced settings window and submit the logs to my email, [email protected] with a reference link to this forum topic.
