Beta crashing
Beta keeps crashing for no reason, Just sitting open, no explanation, and when I restart it says “recovery failed” . I have to to a backup restore every time this happens.
Check your memory usage while you have em Client open. I’ve noticed the current beta uses ten times as much memory as 10.
What sort of memory usage are you getting with eM Client 11 Beta when idle ?
Also is this with just one instance of eM Client ?
Also what Beta version are you using ?
Also is this with Windows or Mac & what OS ver ?
Yes, just one instance on Windows. Memory use is at 100mb give or take. I am going to have to go back to 10, as it stands it is unusable to me, constant crashing and won’t recover, have to do a restore each time. Taking me 3 times as long as normal to take care of emails.
