Does this install as 64bit or will I need to uninstall it and install the msi version to get the 64bits?
The new installer is designed to install only the components for your system. We recommend following the installation instructions in the BETA blog:
If you have a previous major version of eM Client installed (eM Client 10 and older) install using the MSI.
If you don’t have any eM Client installed (for example, if you uninstalled it manually), install using the new MSIX installer.
If you use 64-bit system, both ways should install the 64-bit version of eM Client for you.
