I ran one prompt and it worked for less than two minutes and cost $10… Thankfully I had set a $5 limit and somehow it still billed $10 before I got an error (OpenRouter).. It seems eMClient’s context management is… lacking. It must not be doing any distillation of your emails and just appends every single one to a prompt in raw form.. This will cost a ton, cause hallucinations and probably just fail in the end.. So this needs some major work, although I love the concept.
Some ideas..
Build a tool to convert emails to text before you add them to context.
Use sub-agents to process large results in batches.
Use Jev to do filtering quickly and cheaply (e.g. “the email is about upcoming events”).
Build a semantic search index (e.g. Qdrant).
Oh, the model was gpt-6.1-sol.. so I tried cheaper models like Deepseek v4.1 Flash and Haiku 5.5 and they just fail repeatedly to make tool calls so it seems the harness needs a lot of work still.
