I use the em-Client for my contacts under Windows. Some contacts get an \ added in the SORT-STRING field. I use “last name”, “first name” in the SORT-STRING field. The \ is added in front of the comma and when you save again, you get another .
I sync my contacts to my ownCloud (version 6.0.2) via cardDAV. Never had this problem with Thunderbird.
Hi Martin, as you mentioned yourself, the issue is really held within Owncloud, the issue has been reported and we’re still waiting for a fix, unfortunately that’s all we can do at the moment, it might help if you report the issue yourself as well. The more the better.
this issue is still not fixed in em 6.0.21040 and OwnCloud 7.02. Never had problems with any other OC CardDav clients. EM seems to trash slowly my cardav entries on the server ebcause I hardly have a chance to alter some card entries in em: almost everytime an error occurs saying that the server doesn’t support this or that feature. Even if only altering a typo in the name… Seems em is not capable of talking with owncloud card service at all in a usable manner…? As I said: no other client does have these problems (TB, CardDav(Android), Webclient)
Is there a cance this will be fixed in near future? I’m in test phase, thinking about changing a bunch of installation from TB to EM…
Hi, I’m sorry this issue is causing issues while using eM Client with OwnCloud, but just as I previously stated, this is unfortunately an OwnCloud issue, that has been reported several times, we believe the best solution for this issue is to report the issue to OwnCloud so the synchronization can work properly with all CardDAV clients without the need to workaround the issue.
The issue is still open in ownCloud 7.0.4 (stable), I left a comment on the oc bug tracker, but as we are few em client users, there won’t be enough “pressure” - and all “mayor clients” (iphone contacts, android) seem to do a workaround - the chances are not good to get the “right” solution from oc. So maybe a workaround on em client would be the better solution for your customers, even if it is not your bug…
Hi, I’m sorry for the ongoing issues with Owncloud, I’ve submitted a workaround request to the developers, as the issue seems to be unresolved for quite a long time, hopefully the workaround could be included in one of the upcoming releases.
