Hi there,
em client autostart only works sporadically under Windows 10 64Bit. Is there a solution / update for this?
Hi there,
lunes 25 octubre 2021 :: 1356hrs (UTC +01:00)
Hi @startstop
Your post is Autostart don’t work is listed under Crashing eM Client.
Do you have both issues?
Personally I have disabled Autostart as I found it was problematic even on a very high spec computer.
The sporadic issue is probably as the result of the length of time eMC takes to load its database and or conflicts with other systems/programs starting - what starts first?
Simply start eMC when your system is running.
Skybat
[email protected]
Its a new Notebook only runs Teams and EMclient. The customer only want the autostart…
lunes 25 octubre 2021 :: 1614hrs (UTC +01:00)
Hi @startstop
I am sorry I cannot help you further with this, however, I do not believe it is an eMC issue.
For further help please raise a ticket with eMC support.
Skybat
[email protected]
