Hello.
I’m needing to perform the eM Client back-up that can be configured within eM Client using a command script. The reason for this is that I need to use a NET USE statement to set the UNC path and credentials needed for the back-up of the eM Client data to my NAS.
I was able to find this command line syntax provided by Gary at eM Client in response to another inquiry:
“C:\Program Files (x86)\eM Client\MailClient.exe” /dbbackup -backup
It appears that executing this command actually backs up the eM Client data to the UNC path I have configured in Menu | Settings | General | Backup | Target Directory, which is interesting.
If I uncheck the “Enable periodic backup” check box on the Backup configuration dialog box, will running the command line statement from a script continue to use the UNC path I have configured in the Backup configuration dialog box?
Alternatively, is there a way for me to specify the back-up UNC path directly on the eM Client back-up command line (from above)?
Thank you! ![]()
Lisa
