is there a way to automaticaly encrypt while sending only for specified e-mails? If not it would be great to have such option (like a enryption white list).
For now I see that the only options are to either
enable for all or
for none or
to indivualy select everytime when sending.
This makes it easy to forget encrypting and makes the use of e-mail encryption not very intuitive.
@Gary I started using eM Client and set it to encrypt by default. However, when sending e-mail to recipients whose keys are not available, a popup windows always requires me to confirm that I want to send that particular message unencrypted. Is there a way to tell eM Client to “encrypt by default if a key is available” ?
I think you have that setting already selected, so every message you send will be encrypted, as long as you have the recipient’s public key. If you don’t have their key, then you are given the popup asking if you to confirm you want to send unencrypted.
It would be very practical if the encryption functionality in eM Client could be set up as follows:
If I have entered a digital certificate (SMIME or PGP) for my account, then I’d be able to pick the following settings:
1.1 Always sign emails
1.2 Always include my public key in the email
1.3 Auto-encrypt if the public key of email recipient is present
Expected behavior:
2.1 When receiving an email that includes a public key, auto-insert it in my library
2.2 When sending to two recipients and there’s a public key for one of them, but not the other, then:
2.2.1. Auto-encrypt the email to the recipient for whom I have a public key
2.2.1.1 If I have a GPG private key for my account, and there is a GPG public key in my library for the recipient, auto-sign & encrypt the email using the GPG option
2.2.1.2. If I have an SMIME private key for my account, and there is an SMIME public key in my library for the recipient, auto-sign & encrypt the email using the SMIME option
2.2.2.3. If both I and the recipient have GPG and SMIME keys, use the preferred method that I have selected
2.2.2. Auto-sign the email to the recipient for whom I do not have a public key, as follows:
2.2.2.1. If I only have either GPG or SMIME, use the one that I have
2.2.2.2. If I have both GPG and SMIME private keys, use the preferred method that I have selected
Thank you for your prompt reply. Good to know that it’s already been implemented, good work!
However, there should be an option to do this “silently”, i.e. not to ask for confirmation when sending to a recipient for whom there is no public key!
If there are two recipients and one has a public key and the other does not.
And I’m prompted to send the email unencrypted.
Does it go to both recipients unencrypted?
The popup asks if you want to send it unencrypted.
If you choose YES, the message is sent unencrypted, to both recipients.
If you choose NO, the message is not sent and you remain in the compose window.
