I’m trying to configure our email domain so that em Client can autodiscover the settings.
I’ve created an SRV record pointing to a domain which serves an autodiscover.xml file generated via CGI script to be appropriate for the user.
em Client picks up the settings correctly (IMAP, server name, ports), but never prompts the user for a password.
When you access the automatically configured account the authentication is set to ‘Use integrated Windows authentication (SSO)’ instead of username and password.
If you manually change this to username and password the dialog displays the correct username picked up from the autodiscover.xml.
Is there a way to tell em Client to prompt the user for a password as part of the autodiscover process?
This is the autodisover.xml that gets served (the $variable bits get replaced with appropriate values based on the email address provided by em Client in the autodiscover process):
<?xml version="1.0" encoding="utf-8" standalone="no" ?>
<Autodiscover xmlns="http://schemas.microsoft.com/exchange/autodiscover/responseschema/2006">
<Response xmlns="http://schemas.microsoft.com/exchange/autodiscover/outlook/responseschema/2006a">
<Culture>en:us</Culture>
<User>
<DisplayName>$name</DisplayName>
<EMailAddress>$email_address</EMailAddress>
</User>
<Account>
<AccountType>email</AccountType>
<Action>settings</Action>
<Protocol>
<Type>IMAP</Type>
<Server>$email_server</Server>
<Port>993</Port>
<SSL>on</SSL>
<SPA>on</SPA>
<DomainRequired>off</DomainRequired>
<LoginName>$userid</LoginName>
<AuthRequired>on</AuthRequired>
</Protocol>
<Protocol>
<Type>SMTP</Type>
<Encryption>TLS</Encryption>
<Port>587</Port>
<SPA>on</SPA>
</Protocol>
</Account>
</Response>
</Autodiscover>
