Although " auto reply" is a server side feature, it would be very useful to have it. If it could run even if the workstation is turned off, it would be even better! Thank you! — NOTE: If it can’t be implemented, PLEASE let us know how to achieve this through Rules, because I couldn’t find the way. Thanks!!
Like wise… I need to know how to set this up through Rules…
Hi, thank you for the suggestion Sandra, we’ll consider adding this feature to future releases.
Thank you Paul! At least just an option to “reply to sender with a template” in the rules’ list. Thanks for your consideration!
