Auto Backup fails!
I keep getting this message every morning when (I assume) em Client is trying to back up. Backup fails each time. I think this started after a recent update but I can’t be sure.I tried doing a repair installation but it made no difference. I can do a manual backup with no problems.
Any ideas how to fix this please?
I also get another window saying 'The filename, directory name or volume label syntax is incorrect. I don’t believe I have changed anything recently. This started about 3 weeks ago.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: The filename, directory name, or volume label syntax is incorrect.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.Threading.Mutex.<>c__DisplayClass3.b__0(Object userData)
at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData)
at System.Threading.Mutex…ctor(Boolean initiallyOwned, String name, Boolean& createdNew, MutexSecurity mutexSecurity)
at System.Threading.Mutex…ctor(Boolean initiallyOwned, String name, Boolean& createdNew)
at DbBackup.MainForm.IsOtherInstanceRunning(Int32 timeout)
at DbBackup.MainForm.CheckMailClientRunning()
at DbBackup.MainForm.MainForm_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5472 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
DbBackup
Assembly Version: 6.0.19861.0
Win32 Version: 6.0.19861.0
CodeBase: file:///C:/Program%20Files%20(x86)/eM%20Client/DbBackup.exe
Win32 Version: 2.0.50727.5468 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5467 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Xml
Win32 Version: 2.0.50727.5476 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
appl JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.ication or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
Hi, do you use multiple Windows accounts with locked personal folders and into which one you are trying to backup?
Jan
Hi Jan, thanks for your reply.
I use two Fastmail accounts, one is my main mail account and the other is a rarely use Fastmail account that is used for admin messages and confirmation of my account status byFastmail. The database is located in C:\Users\Mike G\AppData\Roaming\eM Client\ and the backup destination is the F: partition on my hard drive (F:\eM Client Backup). I’m sorry, but I don’t know what you mean by ‘locked personal folders’!
The auto backup worked fine for a long time but I noticed that along with the error message posted above, that the daily backup always showed no data as the event was failing. The folder in F: would be uploaded to a cloud account but of course no data was being uploaded!
Hope this helps.
Thanks
Mike.
Hi. I’m just wondering how long I need to wait for a response from eM Client that will enable the software to run properly as it is now 36 days since I posted the original question?
Can anyone please assist me with this as at this rate I will probably ditch the software with what appears to be nil support!
Thank you.
Hi sorry for the late reply,
Could you please go to “Scheduled Tasks” find eM Client in “Task Scheduler Library”, click on it and export the .xml file provided by the application?
Save it somewhere to your computer and send it to us to [email protected]
Thank you, and again sorry it took so long to reply.
