how can i add all contacts? i added accounts and it has no contacts, is there a way to make it automatic add all contacts from all emails in inbox to addressbook?
Does your email account provider supports contacts synchronizing? Go to Tools - accounts - your account and tell me if you have contact (or contacts and something tab).
John
The only tabs are General, Imap, Smtp, Diagnostics. The email is @aol.com
Is it not possible for it to just create an addressbook from all emails in my inbox? I can manually add them, 1 at a time, but there are hundreds…
Then you do not have Contacts enabled, have you used automatic setup? If not then recreate your account using automatic setup or under Tools - accounts - new account - contacts - other create account for contacts.
Jan
Thanks a lot, that solved it, aol seem to use carddav and I was able to get all my contacts in.
thank you for update on your issue.
Jan
