Asignar tareas a otros usuarios
Hay alguna forma de asingar tareas a otros usuarios dentro de la organización?
Is there a way to assign tasks to other users within the organization?
Yes. Tasks are stored in Calendars but this is not possible with all Calendar providers. Google Calendars for example don’t support this.
Just click on the Show Advanced options in the Task.
Many thanks Gary, but I can´t find the Advanced Option in Task and the assign to box it´s not shown.
I use Microsoft 365 Calendar so I think it works on exchange and I don´t know if it support it.
I have check in Tasks main menu the option: “Always show advanced options”
but I don´t see this option
This field is not supported on Exchange accounts. Sorry.
Ok many thanks. Any possibility to improve that option for Exchange accounts?
