Archive does not work
Why don’t I see Archive in the menu? It shows up when I select ‘Customize . . .’ But then disappears when I close Customize. Nor does it appear if I select a particular email.
Is this in V11 Beta ?
If it is, this has been fixed in the later V11.0.196 via the release history page.
It’s 11.0.1389 (8b6849e). Where can I get the newer release? It doesn’t appear in Updates.
If you already have V11.0.1389 “that is the latest public version atm”. The Archive button appears on the toolbar for me personally and doesn’t dissapear on Windows or Mac.
So if your Archive button is still dissapearing or not working correctly, then could be you might have a problem with either your eM Client Installation or your Database. So i would suggest to create a new database & uninstall and reinstall eM Client.
So first if you have a POP account or Messages etc in Local folders, then go to “Menu / File / Export” and export any messages, contacts, calendar data, tasks & notes you need to a folder on your desktop or downloads.
If you have any Tags, Rules, Signatures, Templates etc you can export those via the (.xml) export option. Then continue below.
If you have a IMAP, Exchange, Office 365, Graph or iCloud account and nothing in Local folders unless you need to export anything, just continue below.
Next “Close eM Client” and then go to the following hidden database folder and “rename it” to eg: eM Client-old"
(Hidden database folder Mac)
/Users/User Name/Library/Application Support/eM Client
Then once the database is renamed “uninstall eM Client 11” and then if you originally reinstalled eM Client from the website, go to the release history page and download and reinstall and setup as new and see if the Archive buttons stays there & works. If it does work then make a manual backup via “Menu / Backup” to save that.
If you had an IMAP, Exchange, Office 365, Graph or iCloud account then all your messages messages, contacts, calendar data, tasks etc will come back from the server end once eM Client reconnects to your server. Then if you exported anything earlier reimport that.
If you had a POP account or Messages etc in Local folders then once setup & working, go to “Menu / File / Import” and re-import all your messages, contacts, calendar data, tasks & notes etc back into eM Client from your exported folder on your desktop or downloads.
Lastly if uninstalling and reinstalling the program and creating a new clean database still has the same Archive button issue, then suggest next if you have a current active paid Pro, Personal or Business license, go to the VIP Support page and login and lodge a support ticket for offical assistance.
If you have run out of your 12 months support time, you can get another year extention via the following page VIP Support Extension | eM Client
are you kidding? for a bug in your software?
