Pouquoi les courriels provenant du même expéditeur ne sont pas automatiquement regroupés sous, par exemple, un triangle noir droit qu’on peut cliquer/ouvrir n’importe quand?
Merci. Gabriel
If you display the right Contacts Sidebar, you will see all messages from the sender of the selected message listed there.
Hi Gary,
SPLENDID,as they say in the UK! Actually, in the French version, I have to clic on «Historique» (top right) and there they are, absolutely ALL of them!
Thanks a lot for your precious help, and your time, Gary
Gabriel
