A Local POP account desktop calendar wont sync to the mobile app or any other client “as it’s not server cloud based” and only local to the client.
So if you want to sync the calendar between the desktop client and the mobile app and your server has calendar support, then suggest you add your account again “as an IMAP account setup” via “Menu / Accounts” and “select your calendar” when adding your account which then will work with the QR Export and show your calendar in the app.
If your server doesn’t support a calendar, then you would either need to use another different eg: server based “CalDAV or Fruux calendar” to add in manually, or use an alternate free or paid account like a Gmail.com or Outlook.com etc which has cloud server calendar support builtin.
The Mobile iOS & Droid app currently supports the following Server based cloud calendars.
Lastly, if you do change to an IMAP account setup which has calendar support, “don’t delete your POP account” and "first setup your IMAP account.
Then once your IMAP account is setup, move all your existing POP mail to the same folders in your IMAP account. Once you are confident its all there, then remove your POP account.
Danke , Danke.
Wau , dann habe ich das ganze Falsch Verstanden. ( habe immer nur Pop3 verwendet , all die jahre )
Server , sowas habe Ich nicht, , Ich komme vom Epim ( mail Programm )
muss mich somit total umstellen.
Wie gesagt , mail ist mir unwichtig , wichtig ist für mich der kalender auf dem Phone zu haben.
Am PC zu Bearbeiten und auf dem Phone zu haben.
Ich versuche jetzt mal Euren Weg zu gehen und schaue aber auch gleich noch diesen Weg an ( calDAV )
Sage Danke , und versuche Euren Weg zu gehen. ( mich um zu stellen )
