Hi there,
I’m using eM Client for a couple of years now. My current version is 9.2.
I struggle with managing my achieve of e-mails from previous years. The way I’ve done it so far is to create under “Local Folders” a separate folder for each year (i.e. 2024 or 2023 and so on). In these folders I store all my e-mails, additionally sorted in specific categories, threads, etc.
The above solution, however, is getting quite complex and heavy after a couple of years, as my achieve of e-mails has grown a lot - I have six big folders for each year from 2019 to 2024.
My question: is there a way in eM Client (maybe in the most recent version) to export e-mails into a specific file / separate database? What I’m thinking of is to export all e-mails i.e. from 2022 and 2023 into a specific file/database to which I could easily connect when necessary (in order to search for some e-mail) and then disconnect it.
This is exactly how .pst files work in MS Outlook, where you can flexibly choose which .pst file (with a folder structure inside of it) open in your Outlook, depending on your needs.
Thanks,
Robert
