Sometimes – not all the time and not with all address – I get the message "An attempt to connect to
failed. This could be caused by temporary server unavailability or incorrect settings. Do you want to check the settings?" Sometimes I get no error messages and the Send/Receive completes, sometimes only a few addresses fail and sometimes all addresses fail. If I do a Send/Receive on each individual address, it goes without an error. All the addresses are handled by GMail. I'm on a trial install and would like to resolve this before I pay for a Pro version of the eM Client. I checked the forum and in all posts I read that talked about this problem, the answer was to send in a log, but when I sent in the log, I'm told that I can't use that support because I don't have a Pro account.Hello Allyn, unfortunately I’m not quite sure what error is this referring to, can you please make a screenshot of the error and when it occurs, switch to the log tab and copy the content of the log from the Operations window as well? Submit the screenshot and the logging details to us here on the forum for more information about this issue.
Also, can you please check the eM Client release number of your current eM Client installation in Help > About?
It seems like you’re using a security software on your computer that is blocking the connection to the server, please make sure to disable it or setup an exception for eM Client in order to let the application connect to the server.
Hope this helps,
An exception is already created. If the problem is security software, wouldn’t it block it all the time? As I said in the original post, sometimes the Send/Receive goes without an error, sometimes only some of the addresses get an error and sometimes all the addresses get an error. If security software is blocking it, all the addresses would get an error all the time, yes?
several of the email addresses aren’t redacted. For the sake of privacy, could these images be removed if you saw what you wanted to see in them?
No, security applications block certain ports (mostly the insecure ones, sometimes the other way around). It’s important to assure the application is not blocking the connection, thus please try to disable the security temporarily.
Your application may be blocking the incoming port running on insecure security policy. Unfortunately the error suggest the connection is being closed remotely, thus I believe your security software is blocking it or the issue is caused by temporary unavailability of your mail server.
As I already said, there is an exception already in the security software. I disabled it and the errors still occurred – sometimes on all addresses, sometimes on only a few of the addresses and sometimes I got no error at all. My mail is handled by GMail. I doubt the mail server is unavailable a few dozen times each day. I have other email in Thunderbird. I don’t get these errors in Thunderbird.
Hello again, for more information, please navigate to Tools > Settings > Advanced and enable logging for the problematic account(s), enable logging for IMAP/POP (based on what errors you’re getting), save the settings and replicate the issue.
Once the error reoccurs, please restart the application and go back to the advanced settings window to submit the logging data. Please send the logs to my work mail, mcgregor@emclient.com with a reference link to this forum topic.
I get this error a lot too, have you figured anything out?
Hi Evan,
please try to make an exception in Windows firewall and any Anti-virus software you use, as it could be blocking the connection to the server.
If that doesn’t help, please copy the content of the third tab of the Operations window (Log) here for more details about the problem.
6:46:34 AM Online state: changed to online due to NetworkAvailability 6:46:34 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
6:46:34 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
6:46:35 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
6:46:35 AM sullivan.evan@gmail.com [IMAP] Uploading messages: To folder sullivan.evan@gmail.com/[Gmail]/Sent Mail
6:46:35 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
6:46:35 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
6:46:35 AM esullivan@ashwaubenonk12.org [GData] Uploading item(s) to folder ‘esullivan@ashwaubenonk12.org/Calendar/’
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
6:46:35 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: For folder esullivan@ashwaubenonk12.org/Inbox
6:46:36 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: Done
6:46:36 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
6:46:36 AM sullivan.evan@gmail.com [IMAP] Uploading messages: Done
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
6:46:36 AM MailExceptions.OperationException: Uploading item(s) to folder ‘esullivan@ashwaubenonk12.org/Calendar/’ failed due to the following error: Invalid attendee email. —> Google.GoogleApiRequestException: Google.Apis.Requests.RequestError
6:46:36 AM Invalid attendee email. [400]
6:46:36 AM Errors [
6:46:36 AM Message[Invalid attendee email.] Location[-] Reason[invalid] Domain[global]
6:46:36 AM ]
6:46:36 AM —> System.Net.WebException: The remote server returned an error: (400) Bad Request.
6:46:36 AM at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
6:46:36 AM at Google.Apis.Requests.Request.InternalEndExecuteRequest(IAsyncResult asyncResult)
6:46:36 AM — End of inner exception stack trace —
6:46:36 AM at Google.Apis.Requests.ServiceRequest1.EndFetchInternal(IAsyncResult asyncResult) 6:46:36 AM at Google.Apis.Requests.ServiceRequest
1.EndFetch(IAsyncResult asyncResult)
6:46:36 AM at MailClient.Protocols.Gdata.FetchHelper.FetchWithCancellation[T](ServiceRequest1 request, CancellationToken cancellationToken) 6:46:36 AM at MailClient.Protocols.Gdata.CalendarItemSynchronizer.Upload(IItemUploadContext
1 uploadContext, Folder folder, IEnumerable1 items, CancellationToken cancellationToken) 6:46:36 AM at MailClient.Protocols.Common.ItemSynchronizer
2.<>c__DisplayClass20.b__1c(WorkerStatus status, CancellationToken cancellationToken)
6:46:36 AM at MailClient.Protocols.Gdata.GenericGapiCommand.Execute(WorkerStatus status)
6:46:36 AM at MailClient.Commands.Command.Process(WorkerStatus status)
6:46:36 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
6:46:36 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
6:46:36 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/Inbox
6:46:36 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
6:46:37 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Directory/'
6:46:37 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
6:46:37 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
6:46:37 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
6:46:38 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/'
6:46:39 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
6:46:39 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
6:46:39 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Evan Sullivan/'
6:46:55 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/[Gmail]/Trash
6:46:56 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
6:46:56 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/[Gmail]/Spam
6:46:57 AM sullivan.evan@gmail.com [IMAP] Downloading message part…
6:46:57 AM sullivan.evan@gmail.com [IMAP] Downloading message part…: Done
6:46:58 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/[Gmail]/Spam
6:46:59 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
6:46:59 AM sullivan.evan@gmail.com [IMAP] Copying messages
6:46:59 AM sullivan.evan@gmail.com [IMAP] Copying messages: Done
6:46:59 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/[Gmail]/Spam
6:47:01 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/[Gmail]/Trash
6:47:01 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/[Gmail]/Trash
6:47:01 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
6:47:01 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
6:47:02 AM sullivan.evan@gmail.com [IMAP] Downloading message part…
6:47:02 AM sullivan.evan@gmail.com [IMAP] Downloading message part…: Done
6:48:20 AM sullivan.evan@gmail.com [IMAP] Copying messages
6:48:20 AM sullivan.evan@gmail.com [IMAP] Copying messages: Done
6:48:20 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/Inbox
6:48:20 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
6:56:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
6:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
6:56:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
6:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
6:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Directory/'
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
6:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
6:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/[Gmail]/Trash
6:56:34 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
6:57:46 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/Inbox
6:57:46 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
6:57:58 AM sullivan.evan@gmail.com [IMAP] Downloading message part…
6:57:58 AM sullivan.evan@gmail.com [IMAP] Downloading message part…: Done
6:57:59 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/Inbox
6:57:59 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
6:58:11 AM sullivan.evan@gmail.com [IMAP] Copying messages
6:58:11 AM sullivan.evan@gmail.com [IMAP] Copying messages: Done
6:58:11 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/Inbox
6:58:11 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
7:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
7:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
7:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
7:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
7:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Directory/'
7:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
7:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Evan Sullivan/'
7:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/'
7:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
7:12:05 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
7:12:05 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
7:12:05 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
7:12:06 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
7:12:06 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
7:12:06 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
7:12:07 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
7:16:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
7:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
7:16:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
7:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
7:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
7:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Directory/'
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
7:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
7:16:41 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: For folder esullivan@ashwaubenonk12.org/Inbox
7:16:41 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: Done
7:16:45 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
7:16:45 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
7:16:46 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:16:46 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:24:02 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
7:24:02 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
7:24:02 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
7:24:03 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
7:24:03 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
7:24:03 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
7:24:03 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
7:24:20 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:24:20 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:24:58 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
7:24:58 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:24:58 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
7:24:58 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
7:24:58 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:24:59 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
7:24:59 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
7:24:59 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
7:24:59 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:25:02 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
7:25:03 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
7:25:03 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
7:26:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
7:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
7:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Contacts/'
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
7:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
7:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/Directory/'
7:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
7:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder 'esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/'
7:26:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Contacts/'
7:26:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder 'sullivan.evan@gmail.com/Evan Sullivan/'
7:27:25 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
7:27:25 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
7:27:26 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
7:27:26 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:27:26 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:27:26 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
7:27:28 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
7:27:28 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
7:27:29 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:27:29 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:28:05 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
7:28:05 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:28:05 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:28:05 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
7:28:05 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
7:28:06 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
7:28:06 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
7:28:06 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
7:28:06 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
7:28:11 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
7:28:11 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
7:28:11 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:28:11 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
7:28:15 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
7:28:15 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
7:28:15 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
7:28:15 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
Just installed yesterday and I am getting the same error periodically.
Happened again
10:42:04 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: For folder sullivan.evan@gmail.com/[Gmail]/Spam10:42:05 AM sullivan.evan@gmail.com [IMAP] Synchronizing messages: Done
10:42:06 AM sullivan.evan@gmail.com [IMAP] Downloading message part…
10:42:06 AM sullivan.evan@gmail.com [IMAP] Downloading message part…: Done
10:42:07 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/[Gmail]/Spam
10:42:07 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
10:42:08 AM sullivan.evan@gmail.com [IMAP] Copying messages
10:42:08 AM sullivan.evan@gmail.com [IMAP] Copying messages: Done
10:42:08 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: For folder sullivan.evan@gmail.com/[Gmail]/Spam
10:42:08 AM sullivan.evan@gmail.com [IMAP] Synchronizing message flags: Done
10:43:38 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:43:38 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:43:52 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
10:43:52 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:43:52 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
10:43:52 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
10:43:52 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:43:53 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
10:43:53 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
10:43:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:43:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:43:54 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
10:43:54 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:43:54 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:43:57 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
10:43:57 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
10:43:57 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
10:43:58 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
10:44:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: For folder esullivan@ashwaubenonk12.org/Inbox
10:44:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: Done
10:44:56 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…
10:44:56 AM esullivan@ashwaubenonk12.org [IMAP] Downloading message part…: Done
10:44:57 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:44:57 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:45:06 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:45:06 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:45:12 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
10:45:12 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:45:12 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:45:12 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
10:45:12 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
10:45:13 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
10:45:13 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
10:45:13 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
10:45:13 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
10:45:13 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:45:14 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:45:14 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
10:45:14 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
10:46:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
10:46:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
10:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
10:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
10:46:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
10:46:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
10:46:34 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/’
10:46:34 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
10:46:34 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Evan Sullivan/’
10:50:52 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages
10:50:53 AM esullivan@ashwaubenonk12.org [IMAP] Copying messages: Done
10:50:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
10:50:53 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
10:56:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
10:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
10:56:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
10:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
10:56:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
10:56:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
10:56:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
11:01:46 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
11:01:46 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
11:01:55 AM esullivan@ashwaubenonk12.org [SMTP] Connecting: To esullivan@ashwaubenonk12.org
11:01:55 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: For folder esullivan@ashwaubenonk12.org/Inbox
11:01:56 AM esullivan@ashwaubenonk12.org [SMTP] Connected: To esullivan@ashwaubenonk12.org
11:01:56 AM esullivan@ashwaubenonk12.org [SMTP] Sending messages
11:01:56 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing message flags: Done
11:01:56 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: From esullivan@ashwaubenonk12.org
11:01:56 AM esullivan@ashwaubenonk12.org [SMTP] Disconnected: Done
11:01:56 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: To folder esullivan@ashwaubenonk12.org/[Gmail]/Sent Mail
11:01:57 AM esullivan@ashwaubenonk12.org [IMAP] Uploading messages: Done
11:03:59 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: For folder esullivan@ashwaubenonk12.org/Inbox
11:03:59 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: Done
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
11:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
11:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
11:06:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
11:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
11:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
11:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
11:06:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
11:06:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Evan Sullivan/’
11:06:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/’
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
11:16:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
11:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
11:16:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
11:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
11:16:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
11:16:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
11:16:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
11:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
11:26:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
11:26:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
11:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
11:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
11:26:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/esullivan@ashwaubenonk12.org/’
11:26:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
11:26:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
11:26:34 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Evan Sullivan/’
11:34:29 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: For folder esullivan@ashwaubenonk12.org/Inbox
11:34:29 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing messages: Done
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
11:36:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder list
11:36:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder list
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
11:36:33 AM sullivan.evan@gmail.com [GData] Synchronizing folder ‘sullivan.evan@gmail.com/Contacts/’
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
11:36:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Contacts/’
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info/PLTW
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/School
11:36:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Testing
11:36:33 AM esullivan@ashwaubenonk12.org [GData] Synchronizing folder ‘esullivan@ashwaubenonk12.org/Directory/’
11:36:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Taxes
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: Done
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Inbox
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: Done
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Inbox
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Support
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/[Gmail]
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/[Gmail]
11:46:33 AM esullivan@ashwaubenonk12.org [IMAP] Synchronizing subfolders: For folder esullivan@ashwaubenonk12.org/Info
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/HoldOnTo
11:46:33 AM sullivan.evan@gmail.com [IMAP] Synchronizing subfolders: For folder sullivan.evan@gmail.com/Evan/Paid Bills
Hi Evan,
unfortunately there is nothing telling in these logs, though the previous one suggests that there is a faulty event in your Google calendar.
Did you perhaps have any problems sending event invitations to a certain event/attendee?
I normally don’t send invites although there might be one or two in there. I do get a message when I launch Em. Uploading error failed due to invalid attendee, but it doesn’t tell me what event or what attendee, so I can’t fix it
I wasn’t doing anything with my calendar and I am still getting this error.
hello nobrien, you did not include your logs, so it is hard to say if your issue is the same, as the error message itself can cover many more issues.
This is all that is in the Logs:
02/03/2016 16:49:13 1 no such table: mail_fti.SubjectIndex_stat02/03/2016 16:49:13 1 no such table: mail_fti.AddressIndex_stat
02/03/2016 16:49:13 1 no such table: mail_fti.LocalMailsIndex3_stat
02/03/2016 17:41:01 1 no such table: mail_fti.SubjectIndex_stat
02/03/2016 17:41:01 1 no such table: mail_fti.AddressIndex_stat
02/03/2016 17:41:48 1 no such table: mail_fti.SubjectIndex_stat
02/03/2016 17:41:48 1 no such table: mail_fti.LocalMailsIndex3_stat
02/03/2016 17:41:48 1 no such table: mail_fti.AddressIndex_stat
02/04/2016 19:21:31 1 no such table: mail_fti.SubjectIndex_stat
02/04/2016 19:21:31 1 no such table: mail_fti.AddressIndex_stat
02/04/2016 19:21:31 1 no such table: mail_fti.LocalMailsIndex3_stat
This is the error that I repeatedly get:
What’s in the log tab of the error is not in the logs sub-directory. Where can I find that info to send to you?
