Alt + M does NOT work for calendar month view
In calendar view, pressing alt + M opens the menu, NOT the month view. The web help says alt+m should open month view and “Month” has the “m” underlined indicating accessibility via alt. However, I cannot get month view selected.
Is there a keyboard shortcut to switch to month view?
It is odd that there are two functions with the same Alt shortcut. Actually in this case there are at least three because Alt+M should also toggle completed tasks when in the Task section.
If you have a Pro License, you could open a support ticket.
Thanks, I do have a pro license!
