says 0 days left to register, but I’m already registered
Go to Help --> License and see if it shows that you have a valid license. If so, you can try deactivating the license and then activating it again. If not, your registration did not go through so try activating the license again.
- Merg
Hi, let me know if the above answer helped you.
If you have a license for the product, make sure you’ve entered the license into the application go to Help > License and enter the license key and click on Activate.
