All settings disappeared
Ver: 10.4.5674 (fcbf2a4)
I set up a simple rule that moved received messages to a local folder. I then ran the rule on the local inbox and all the inbox messages disappeared. They were not in the designated local folder. I then closed emClient and restarted it, and the restart was as if it was a new install with all my settings and local folders removed. Unfortunately my backup setting was to keep only one backup , which the program had overwritten with the latest minimal settings. Aaaaarrgghh!
Anyone else experienced anything like this?
  • Richard Kimber
I have now received an email thanking me for choosing emClient
Yes, but “only” when i had changed the Database Location from the default folder to a custom folder by going to Menu > Settings > Storage. I had changed the Current Profile Database Folder and after one or two days everything dissapeared, but it was eM Client that for some reason freaked out and got back to the default path. It seems to be a known problem.
Did you change this as well?
Thanks for replying. I don’t recall making that change, but of course I can’t check that now. I decided to start from scratch by removing and reinstalling emClient.
