Is there a way to set up your alias as the default when you send emails, rather than having to select it from the drop down box each time?
Hi Ben, unfortunately you can not setup an alias as your default sending address, but you might be able to setup the account using your alias instead of the default address and setup all your aliases to that account.
However this might not be supported by your server.
Hope this helps,
