Air Sync error?
Since the update to 10.4.5674 I am getting the following error. (AirSync) Error in Client /server conversion." This happens several times per day and I do not see any suggestions to eliminate it in other posts regarding this error?
Is there anything new in regards to eliminating this error that is driving me nuts??
Thank you!
Richard
That can be if there is a eg: invalid or malformed item in your calendar event, contact, or email that won’t sync to the server and so throws up that error.
So suggest you try clearing the local cache in your mail, calendar & contacts and see if that fixes it.
To clear the local cache in your mail right click on your account “Inbox” and click “Properties” at the bottom and click “Repair”. Then run the repair.
To clear the local cache in your calendar right click on the word “Calendar” directly under your email address (in the calendar section) and click “Properties”. Then click “Repair” & run the repair.
To clear the local cache in your contacts right click on the word “Contacts” directly under your email address (in the contacts section) and click “Properties”. Then click “Repair” & run the repair.
If repairing your account makes no difference then try going to “Menu / Accounts” and remove and readd your account and see if that fixes it.
If removing and re-adding your account still has the same AirSync error, suggest you look at upgrading to V11 which now uses Graph which seems to work great for me personally with my accounts.
Hey “cyberzork” thanks for the reply! Will go through steps as suggested and advise of results.
Richard
Hey “cyberzork” I went through and cleared the cache as you instructed but the error was still there. I then went in and removed the account and then re-added. The error disappeared. Have not had any errors in the last three days! I am not sure if I had just removed the account and that would have done it or did all four steps need to be done?
However Thank you, Thank you, Thank you for once agin coming to the rescue and enabling this nuiscance to be corrected. Very much appreciated…great work!!
Richard
