After system crash eMclent db problem
After system crash eM Clent  db problem. The results after db check is:
System.Data.SQLite.SQLiteException (0x80004005): unable to open database fileunable to open database file
   bij System.Data.SQLite.SQLite3.Prepare(SQLiteConnection cnn, String strSql, SQLiteStatement previous, UInt32 timeoutMS, String& strRemain)
   bij System.Data.SQLite.SQLiteCommand.BuildNextCommand()
   bij System.Data.SQLite.SQLiteCommand.GetStatement(Int32 index)
   bij System.Data.SQLite.SQLiteDataReader.NextResult()
   bij System.Data.SQLite.SQLiteDataReader…ctor(SQLiteCommand cmd, CommandBehavior behave)
   bij System.Data.SQLite.SQLiteCommand.ExecuteReader(CommandBehavior behavior)
   bij System.Data.SQLite.SQLiteCommand.ExecuteNonQuery()
   bij System.Data.SQLite.SQLiteConnection.Open()
   bij MailClient.Storage.Data.DataStore.GetConnection(String relativeName)
   bij DbRepair.CorruptionChecker.CheckCorruption()
   bij DbRepair.FormCheck.Check(Object state)
What to doto solve this problem.
Best Regards, René
Pls Is there anybody who can help me.
Best Rockdaddy
I have the same problem. I have uninstalled and reinstalled multiple times with no results
You posted this 3 days ago and still have not heard from support?
Ok sir here is the fix i used.first go to add and remove programs and uninstall emclient. Then go to your file explorer. You will have to go to view and select show hidden files. Once you have done that you will go to C:user(your computer name./appdata/roaming/emclient and delete that folder. At this point it may be a good idea for you to reboot your computer. The go back and download the emclient and install. This did resolve my problem I hope it helps you.
