After DB Check the Year 2015 is evanish!!! Help Me Please
The tools dbrepairrebuildall not working
Hello Paolo,
did messages from 2015 disappear from your local data or a synced account? Are they still on your mail server if you access it through a webmail interface?
What account did this happen on?
the email is set with pop3 , the db storage size is almost 9gb
Hi Paolo,
do you keep a copy of your messages on the mail server or check it from a different device?
If you only had your data locally, do you have a database backup to come back to?
I did the test on another PC but you do not see 2015 either received or sent there is no way to open mail archive without which the program to create index email ?
asap your reconfirm
Hi Paolo,
POP mail protocol does not synchronize your Sent messages to the server, you’d need to use IMAP for that.
If you do not keep your received messages on the server, they cannot be there when you access it from different computer.
Sounds like your database might have been corrupted and the DB check could not save all your data.
If you keep any data locally, it is always recommended to keep a backup of your database - if you did not do so, then there is nothing to restore your data from.
I’m sorry for the loss.
ASAP RCFM PLS URGENT
