I always need the fields of the Advanced task management in the calendar (like “Label”). Is there any option to open the “create a new date” window always in the Advanced task management mode?
Thomas
Thomas
Can you screenshot where the “Advanced task management” is in the calendar.
New appointment → standard appointment → at the bottom of the new window there ist the option to show Advanced Option:
I would prefer, if I could get this advanced option mask as a standard input mask.
Ok i now see what you mean.
Go to “Menu / Settings / Calendar / General” and place a tick in the box marked “Allways show advanced options”. Then Save & Close settings.
Oh man, I could have found that myself! Super, has worked! Thanks
