Bonjour est il possible d’installer des extensions (addons) de thunderbird ?
Hello, is it possible to install Thunderbird extensions (add-ons)?
eM Client doesn’t currently allow third party plugins / extensions
There is a Sleekplan suggestion for that you can vote for below.
ok j’ai vu merci,
mais avec ce système de votes, autant dire que ça a peu de chances d’être fait.
Alot of the Sleekplan suggestions have already been implemented based on user votes, and alot are also currently in progress and planned as per the Sleekplan Roadmap.
Addons / plugins can be a security risk and can sometimes also cause issues or may not work properly etc, so eM Client focuses on offering built-in integrations rather than relying on external add-ons.
So reccomend you “suggest what type of addon / plugin you would like” that Thunderbird has via the Sleekplan page which then might be able to be implemented in eM Client. Try search there as well as other users might have already suggested it.
With eM Client 11 we will introduce MCP, that can be used for a lot of 3rd party add-on scenarios.
But there is one thing pretty clear. We will never support Thunderbird add-ons. eM Client’s platform is standalone and cannot support add-on formats of different applications.
