Adding Thunderbird addresses
I have just installed eM client … I had an IncrediMail account and a Thunderbird account… I was only allowed to migrate the IncrediMail account, I can’t find out how to transfer the Thunderbird data… Also I can’t find out how to import my address book (in csv )
Is there a pdf file explaining these probably simple problems to an otherwise stupid novice like myself?
I hope that someone somewhere can help…
Best wishes from Davie
“Only allowed”… not sure what that means…
Menu > File > Import click on Thunderbird to begin your import
Been a long time since I imported from TB, but there is an option on the import menu, under files, to import a contact file. Check it out…
Thank you … I will look for and try it…
By “only allowed” I meant that after importing from Incredimail eM Client didn’t allow me to import from TB … But I couldn’t see the option to do this (old age probably :rage:) but I will try your advice… Thank you again :grinning:
