Actualization of Color in Calendar
When I change the tag of an event in calendar, it’s color does not change as expected, because the actual entry is not refreshed. Only after scrolling to the next period and scrolling backwards the color is the right one…
Can you do screenshot examples of that happening and also what calendar are you using.
Also what version of eM Client do you have and are you using Windows or Mac.
It’s Windows10 and EMC 8.2
Which account calendar are you using ?
Or are you using just the local calendar?
