On a new install of emClient, I get asked for my activation key. I put it in and all is well. It shows as activated.
The next day I restart my PC and get asked again, as the key has disappeared. This happens daily and is a real pain.
Is there a solution to this problem, as it’s ,massively irritating!
Maybe the install did not go correctly. try this
on emclient screen
Menu - File - Backup just in case
On your computer
Start button
**Control Panel
program and Features
Find the emclient and right click it
select repair
Or download a fresh copy and re install it. (May have to uninstall the old one first)**
Or, you’re not using it on 2 PC’s are you?
Good catch Jay
License is by PC and the key to license is the email address registered.
If you need it on 2 pc one needs a license on each pc and must have a separate email acct as the registered user on each pc.
Nope, just the single PC. I have moved it from an old PC, which is no longer in use.
Then I would try the repair option as I mentioned above. Backup first and make sure you have the license key.
