Accounts disappeared from view
Since the latest update I have been unable to see the separate email accounts. As a result I cannot access folders with sent mail, or empty the folders with deleted mail. Does anyone know how I can make the accounts reappear?
Hi, please install this version http://www.emclient.com/dist/v6.0.197… it should help you with your issue.
Jan
Thank you. That has solved the problem.
you are welcome :slight_smile:
Jan
