Accessing Contacts
When I click Menu > Tools > Contacts, I am presented with a screen showing contacts I’ve added sometime in the past.  And, for some reason, there appear to be duplicates, which I’d love to get rid of (see menu tools contacts.jpg.)
However, when I click the Contact option on the left navigation column of the eM Client main menu page, the screen shows nothing (see contacts.jpg.)
First, is there any way I can synch these two Contacts choices, and, second, is there a feature that automatically deletes duplicate contacts?
Thanks
You can’t see the contacts in the contact section because local folders are not visible. You can enable them in Menu > Tools > Settings > General > Show Local Folders.
You can remove duplicate contacts by using the Deduplicator tool, which is accessible in Menu > Tools > Deduplicator.
Thanks.  All good.
