I’m using Windows 7. I find the super-thin borders around windows very difficult on the eyes. I’m constantly straining to see where the rectangle ends, and I often click in the wrong place. Is there a theme with thicker borders? Panes of glass stacked on panes of glass is a terrible UI concept. I need more “depth perception”. There used to be shadows, etc.
There are still shadows in the Modern theme, we’re sorry if the UI doesn’t work for you. You can change the theme in Menu -> Tools -> Settings -> Appearances, perhaps you’d like the Modern or the Classic theme more?
Maurice
