A 'delete folder contents' rather than just 'delete'
A ‘delete folder contents’ rather than just ‘delete’ in a folders context menu. This would come in handy to save some clicks on entering the folder, ctrl+a, [shift+]delete. Not a huge deal, I think it makes some sense.
I made a separate post which would probably make the process OK for me as a problem - doing the above causes a big hang when the folder is very large (I tested with 30k emails).
Thanks for listening!
From a user interface perspective this would be a bad addition as it becomes too easy to accidentally delete all contents of a folder. Better human engineering practice is to force the user to think carefully before doing something unintentionally drastic.
Hello Josh,
thank you for sharing your idea on the forums where our developers can consider it as a future improvement.
