A copy to folder rule does not work correctly
After creating a rule to copy certain incoming mail from people that copies the email to another folder it does not execute properly. The email is moved to that other folder instead of just copying it. I want to keep the message in the inbox and also archive it to a selected folder. This rules seems to move and not just copy.
Hello Barry,
can you please tell me what version of eM Client are you currently running? Check the Help>About section for the exact release number.
I tested the copy part of the rule on the v7 BETA and the latest version of v6 and encountered no problem.
If you are sure your eM Client is up to date could you copy the exact conditions of the rule you set up and post them here?
