I get a “Connection Failed” error message straight after upgrading to 7.2.36694.0
eM Client worked fine before that (on Windows 10 system).
The exchange server connection works fine on my iPhone, but no longer eM Client on my PC.
Looking increasing like I need to get rid of eM Client…
Or you can just uninstall that service release then download and install the previous version of eM Client from the Release History. You know that one worked!
But I have been using 7.2.36694 since it’s release with an Exchange server and I am not experiencing any issues. Maybe if you want to stick with that service release, remove the Exchange account from eM Client, then add it again. See if that makes any difference.
Thanks Gary - That worked…
