2 issues with contacts
2 issues with contacts: First, if the category is “None” the contact doesn’t sync with Google. When I add the category it does- weird. Secondly, the phone numbers don’t auto-format like they do in Outlook. For example 3135557777 in outlook automatically changes to (313) 555-7777
The contacts sync with your main contacts folder, note that Gmail is using labels to sort your contacts, thus you need to apply a label (category) in order to see it in for example the “My contacts” category, but I’m sure the contacts are synchronised with the server even when no category is set.
Auto-formatting is not supported.
