Why am I getting a notice to upgrade to 11.0.1257.0? My version is 10.4.5674 (fcbf2a4). Had no idea what it was but tried it anyway and all I got was a download complete and a blank icon on desktop that was 0 size. I am still running W10 pro. Any suggestions as to what I am doing and why am I getting a request to upgrade??
Ron Burnes
If you have a “free personal use non business license” or have a “paid Pro, Personal, or Business (lifetime license)” you would normally get a prompt to update to the latest V11.
So if you do have one of the above versions as V11 update didn’t appear to work “if you originally downloaded eM Client from the website and want to update to the latest version”, then to keep all your existing settings etc, you can download the MSI installer version via the following page that includes (the last) MSI installer: Download eM Client 11 for Windows | eM Client.
The MSI version doesn’t contain the app itself - it keeps your existing file associations and then installs version 11 through the .appinstaller
Note: Before upgrading first make a backup via “Menu / Backup” incase you need to restore for any reason. Also “close eM Client” before upgrading.
Got the msi downloaded with no problem but when I attempt to execute, it tells my it cannot and to check my internet connection. The internet is not the problem or I would not be posting this reply. Appreciate your assistance Cyberzork
Could be possibly a eg: resident program in the background causing the MSI installer not to run.
So if you have any eg: optionally installed firewall / security programs or optionally installed antivirus programs or vpns “other than what comes default with Windows” try completely disabling those to test incase of any interference.
If you have no optionally installed programs like the above then suggest to next “try clearing your Windows temp files” and then “reboot your computer” and see if the MSI installer will then run.
If you haven’t ever cleared your temp files before “close all open programs” and Using the Run Command : Press the WINDOWS + R keys, and type %temp%, and press Enter. This opens the folder containing temporary files, where you can select all items (CTRL + A) and delete them
Nope, still tells me I do not have an internet connection.
Then as you carn’t get the MSI installer to connect, try resetting the Windows firewall to defaults and see if that allows it to connect.
Open the Start menu, and type “Windows Security” in the search bar and select the app.
Click on “Firewall & network protection”.
Scroll down and click “Restore firewalls to default”.
Click “Restore defaults”, then click “Yes” to confirm.
If resetting the Windows builtin firewall to defaults makes no difference, then suggest you then try a clean install with the MSIX installer.
So first make a backup of V10.4.5674 via “Menu / Backup”. You can see when thats completed in “Show Operations” via the dropdown on the right of Refresh.
Once backed up, then go to “Menu / Help / License” and deactivate. Then “close eM Client” and “rename the following hidden database folder” to eg: eM Client-Old or eM Client-V10.
Next “Uninstall eM Client” and then go to the following download page and setup as new. If you have an IMAP, Exchange, Office 365, or iCloud account all your messages, calendar, contacts, tasks etc will come back from the server end when eM Client connects.
Once V11 is setup then go back to “Menu / Help / License” and enter your original license key and activate. If you don’t remember what that was, then go to the following page and enter your email address you originally registered with, and it will be sent to your Webmail where you can then copy that into eM Client.
If you have a POP account or messages etc in Local Folders, “then before closing V10” go to “Menu / File / Export” and export whatever Messages, Contacts, Calendars, Tasks, Notes you need to a folder on your desktop so you can re-import them later after resetting up your account via “Menu / File / Import”.
Also if you have Tags, Signatures, Templates etc that you need from V10, “export those via the Export Settings to .XML option” to a folder on your desktop before closing to re-import later.
[quote=“Anaron, post:5, topic:120366, full:true”]
Hello.
The reason you keep encountering an internet connection error is that eM Client changed its underlying technology in version 11. Version 11 no longer uses a traditional MSI installer for standalone installation; it is now distributed using a modern Microsoft format called MSIX / AppInstaller.
Even if you download the so-called “transitional MSI” to upgrade from version 10 to 11, that file must connect to eM Client’s (and Microsoft’s) servers during installation to validate the deployment of the new application format. If Windows 10 blocks this background communication, you will receive an “no internet” error, even if your web browser is working perfectly.
To bypass this network block and force the installation, use one of the following definitive solutions:
Solution 1: Install directly via the console (Recommended)
Windows 10 includes a built-in tool for installing these new formats, which bypasses errors that might occur in the standard visual installer.
- Click the Windows Start button and type “PowerShell.”
- Right-click on “Windows PowerShell” and select “Run as administrator.”
- Copy and paste the following official eM Client command, then press Enter: [1]
powershell
Add-AppxPackage -AppInstallerFile https://licensing.emclient.com/api/update/emclient.appinstaller
This command instructs Windows to download and install the correct version 11 package for your system directly, resolving issues related to the MSI installer’s redirection.
Solution 2: Use the complete offline installer (.msixbundle)
If your environment or Windows network restrictions continue to block the command above, eM Client developers advise that for a 100% offline installation, you should avoid using the .appinstaller file or the basic MSI installer. You should contact the provider or access their repository to obtain the file with the .msixbundle extension (which contains the entire software package, including all necessary components, with no external dependencies) and install it via PowerShell using the following command:
PowerShell
Add-AppxProvisionedPackage -Online -PackagePath “C:\Path\To\The\Downloaded\File.msixbundle” -SkipLicense
(You must replace the path with the actual location where you saved the file.)
Solution 3: The usual culprit (Disable the IPv6 protocol or proxy)
Sometimes, the Microsoft installer attempts to communicate using the IPv6 network protocol or an invisible system proxy; if your router does not handle this correctly, it may trigger a false “no connection” error.
- Press the Windows + R keys, type
ncpa.cpl, and press Enter. - Right-click on your active network adapter (Wi-Fi or Ethernet) and select Properties.
- In the list, locate “Internet Protocol Version 6 (TCP/IPv6)” and uncheck the box.
- Click OK and try running the version 11 installer again. (You can re-enable it after the installation is complete.)
I just tried the MSI installer link and it is pointing to non-current older version 11.0.1054?
Yes, the transitional MSI is just for a specific version, but appinstaller should check for the newest and install the current update on next run.
Or if you disabled automatic update, you can download and install a newer appinstaller files after you made the first upgrade via the MSI to ensure all file associations are kept.
Being 77 yrs old and legally blind, I am having way too many issues with eMClient for me to deal with. For weeks now I have also had to restore my computer to a previous backup a couple times each week as eMClient can not connect to my reagan.com email and now this! eMClient is no longer worth the effort and will be removed from my computer. I will revert back to both my Gmail and Reagan webmails until I can find a simple workable email program. The best part of my eMClient experience is the people on this forum. You are the BEST!
