Using eM Client 7.2 on my computer, once I delete a task I would like to know if it is retrievable, where might the trash bin [folder] be located.
Hi Fitness,
The Tasks don’t have the delete folder as emails do. The usual use of Tasks is that you mark Tasks as “done” which removes them from the view but these still remain in the folder. However, you can create a folder/subfolder manually and move the tasks there.
Russel
So what you’re saying is…DONE tasks will keep accumulating forever unless you actually delete them and there is no trash bin like emails. So when deleted there is no recovery?
There is an option to HIDE COMPLETED TASKS.
Are DONE tasks separate files in the program folder or 1 compressed file?
Creating a TRASH sub-folder would seem like a good management tool.
Thanks.
