I have having problems with Mail.
My mail server is located in the EST timezone, and I am located in CST. Emclient will assign nonsense timestamps from the future with no real consideration of Windows’ settings.
The result is, past-dated & future-dated items in my mailboxes.
Hi Darius, just want to clear things up. Mail that being received, time stamp is assigned by the sender at the time he/she sent the mail. EM Client uses data/time zone setting in Windows and by no other means.
I use calendar a lot, exclusively MS Outlook at the moment. One of the reasons Outlook works for me is that I can assign a timezone to each start and end time. That granularity is great and important when adding events like flights which begin and end in different timezones. If you’re a traveller, getting times and timezones wrong can be hugely expensive. If eM Client can’t do that, as nice as the rest of it is, I can’t use it.
But I’d like to know when that feature’s finally available.
This is implemented in the version 6 beta. When you add a new event there is an option to specify timezones, when you click it you get a timezone selector for both start and end.
