How can I set RTL as default?
You can do it by using a Template. Go to Menu > Tools > Settings > Mail > Templates and Signatures.
Click on Mail Templates and create a new one. You can find more on creating and using templates in the Help file (F1).
Click in the message body section and choose More > Right to Left. You do not need to enter anything else except to name and close the template. Then set that one as default for new messages or replies and forwards as you need.
Now when you start typing the template will be applied.
Hopefully that should work.
Hay,
I tried what you said, unfortunately still has not solved the problem.
It would be great if, when switching between languages using ALT + SHIFT, such as from English (LTL) to Hebrew (RTL), the software will automatically detect and perform the switch to the right.
Tnx
Nir
