I have just opened my em client and it stays bolcked on “Synchronizing messages”. I dont receive any email and I cant do my work. What can I do?
Check that you have the correct server settings, as provided by your email provider, in your account setup.
Menu > Tools > Accounts
If you still have problems, let us know who your email provider is, if you are using IMAP/POP or Exchange, and maybe someone can give further assistance.
yes, I still have problems. I am using IMAP
the e-mail works ok, till now (yesterday), but now, in the morning suddenly it doesnt and remain blocked
Should I install em client again, or what?
It is not necessary to reinstall eM Client. You can just remove your account and then add it again.
oki, tks I’ll try and I’ll come back
Alina,
Have you resolved this matter?
I have the same issue, just began 2-3 days ago.
I have the same problem
only with gmail
on my mobile app it work perfect
but emclient still
syncing messages
remove and add won`t work
the other accounts works normal
