Pt-br
Olá, estou com o seguinte problema:
Eu recebo emails com aproximadamente 6 paginas, quando vou responder, responder a todos, encaminhar, encaminhar como original, o email é cortado ficando apenas a primeira pagina do mesmo.Funcionando e/ou enviando completo apenas quando envio anexado.
Se necessário encaminho o email original e como fica quando encaminho para vocês.
Este problema começou com a ultima atualização do programa 5.0.18637.0
En google
Hello, I have the following problem:
I get emails with approximately 6 pages, when I reply, reply to all, forward, forward as original email is cut off leaving only the first page of it.Working and / or by sending complete only when sending attached.
If necessary I forward the original email is when and how do I forward to you
This problem started with the last program update 5.0.18637.0
the new version 5.0.18661.0, problem persists.
I will need your SMTP logs, go to tools - settings - advanced, check SMTP under your account, apply and restart eM Client.
Simulate steps that leads to your issue and after that send logs… to [email protected] together with this topic’s URL in subject.
regards
Jan
Pt_br
Problema resolvido, com o pequeno update para versão 5.0.18695.0
Muito Obrigado.
En
Problem solved, with the small update to version 5.0.18695.0
Thank you.
everyone encountering same issue please contact me on [email protected] together with this topic’s URL in subject.
regards
Jan
Hello
We are having the same issue, I tried to Update but EM-CLient is saying there are no updates we are on version 5.0.18661.0 and I’m trying to update to 5.0.18695.0 but I get no updates message, Please Help!!
5.0.18695 is not public, if you are having troubles please follow my previous post about contacting me over email.
regards
Jan
