emClient 7.2.36678.0
Windows 10 Home x64 1903
Configured emClient to NOT hide the popup alert (on getting a new e-mail). Hide popup setting is disabled. Want the popup to remain on the screen, so later when I am not busy then I can check if I want to address the e-mail at that time.
Sent a test e-mail, but emClient never showed its popup window. Its tray icon changed but no popup window. Eventually I figured out to get the popup by disabling the “Use system notifications” option. emClient won’t work with system notifications, whatever those are. emClient is not listed in the apps available to select whether they show notifications or not (Settings -> System -> Notifications & actions). The “Get notifications from apps and other senders” is enabled. The Mail for Windows 10 UWP/WinRT app is listed but disabled since I don’t want to get alerts of new e-mails from that app (because I hope to eventually replace it with emClient).
Only by NOT using system notifications mode will emClient show its popup. However, then the problem is the popup is always-on-top which interferes with my current work. Yes, I got a new e-mail but I’m busy right then and, yes, I want the alert to stick around until I get to a point where I can pause my work and, yes, I want the popup still lingering around so I can check whether or not I want to address that e-mail at that time or wait until later. When I can afford an interruption to check the popup, I still might not want to address it right then but still want the popup lingering around to remind me to check again later.
emClient is not listed as an app for which I can decide if it will present notifications in the Win10 settings, so I cannot select it to show or not show its notification bubble and an entry in the Action Center. When trying to use system notifications mode, emClient won’t show its popup alerting arrival of a new e-mail. With emClient configured to use its own popup instead of system notifications, yep, its popup appears but appears atop every other window to interfere with my use of those other programs. E-mail is important but not so critical to demand my immediate attention and interrupt whatever I’m doing at the time. The building on fire demands immediate attention. An e-mail alert does not. Always-on-top behavior is rude.
