I am
running a zarafa Server which synchronize well with two mobile
devices or with windows 10 mail, contact, calendar client.
Because I dislike the default client of windows I’m trying em Client. The client works well using a Outlock kind of conection configuration with contacts and mails, but it doesn’t work with the calendar. (Which as mentions above works well with other clients.)
I get an exception in the client and another in zarafa. The on in zarafa seams to be ignored, so this should be another problem.
Has anyone an idea what might going wrong?
I have got this log files (address replaced by [email protected]):
edit: "Das angegebene Argument liegt außerhalb des gültigen Wertebereichs." means something like: “Specified argument is out of range .”
em client:
12:22:21 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Calendar/’ 12:22:22 [email protected] [AirSync] MailExceptions.ConnectionException: Das angegebene Argument liegt außerhalb des gültigen Wertebereichs.
12:22:22 Parametername: week parameter is less than 1 or greater than 5 —> System.ArgumentOutOfRangeException: Das angegebene Argument liegt außerhalb des gültigen Wertebereichs.
12:22:22 bei System.TimeZoneInfo.TransitionTime…ctor(DateTime timeOfDay, Int32 month, Int32 week, DayOfWeek dayOfWeek)
12:22:22 bei MailClient.TimeZone.TimeZoneConvert.SystemTimeToTransitionTime(SystemTime systemTime)
12:22:22 bei MailClient.TimeZone.TimeZoneConvert.FromTimeZoneInformation(Byte[] timeZoneInformation)
12:22:22 bei MailClient.Protocols.AirSync.AirSyncCalendarSynchronizer.d__25.MoveNext()
12:22:22 bei MailClient.Protocols.AirSync.AirSyncItemSynchronizer2.<commandstoitems>d__5b.MoveNext()</commandstoitems>_ _12:22:22 bei System.Linq.Enumerable.<selectmanyyield>d__31
3.MoveNext()
12:22:22 bei System.Collections.Generic.List1..ctor(IEnumerable
1 collection)
12:22:22 bei System.Linq.Enumerable.ToList[TSource](IEnumerable1 source)_ _12:22:22 bei System.Linq.Enumerable.ToArray[TSource](IEnumerable
1 source)
12:22:22 bei MailClient.Protocols.Common.ScheduleItemSynchronizeContext1.StoreItems(SynchronizationType type, IEnumerable
1 newItems)
12:22:22 bei MailClient.Protocols.Common.ItemSynchronizeContext2.Synchronize[T](SynchronizationType synchronizationType, IEnumerable
1 items, Func2 getUniqueId, Func
3 hasChanged, Func2 isDeleted, Func
2 convertItems, Action2 updateItem)_ _12:22:22 bei MailClient.Protocols.AirSync.AirSyncItemSynchronizer
2.Synchronize(IItemSynchronizeContext1 synchronizeContext, Folder folder, CancellationToken cancellationToken)_ _12:22:22 bei MailClient.Protocols.Common.ItemSynchronizer
2.<>c__DisplayClass2e.<>c__DisplayClass33.b__2a(WorkerStatus status, CancellationToken cancellationToken)
12:22:22 bei MailClient.Protocols.AirSync.AirSyncGenericCommand.Execute(WorkerStatus status)
12:22:22 — Ende der internen Ausnahmestapelüberwachung —
12:22:22 bei MailClient.Commands.Command.Process(WorkerStatus status)
12:22:23 [email protected] [AirSync] Synchronisiere Ordnerliste
12:22:26 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Posteingang/’
12:22:28 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Outbox/’
12:22:29 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Gelöschte Objekte/’
12:22:31 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Gesendete Objekte/’
12:22:32 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Entwürfe/’
12:22:35 [email protected] [AirSync] Synchronisiere Ordner ‘[email protected]/Junk E-mail/’
z-push error log:
15/10/2015 12:22:23 [1646] [ERROR] [user] Ignored broken message (SyncAppointment). Reason: ‘2’ Folderid: ‘29e2784ae9d14ad2b108b75a2b9422df4300000000000000’ message id ‘29e2784ae9d14ad2b108b75a2b9422dfe14d00000000’
z-push log file:
15/10/2015 12:22:22 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType='DesktopClient’15/10/2015 12:22:22 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:23 [1646] [WARN] [user] Mobile loop detected! Messages sent to the mobile will be restricted to 2 items in order to identify the conflict
15/10/2015 12:22:24 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘FolderSync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:27 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:28 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:28 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:29 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:30 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:31 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:31 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:33 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:33 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:35 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:36 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:22:42 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘Sync’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
15/10/2015 12:26:06 [1646] [INFO] [user] Version=‘2.0.6-1616’ method=‘POST’ from=‘95.91.221.158’ cmd=‘GetItemEstimate’ getUser=‘user’ devId=‘eMClient’ devType=‘DesktopClient’
