Need Favourites Folder (not global inbox!)
  • 2
  • Idea
  • Updated 2 months ago
I see that there are the "Smart Folders", but that is only for global email stuff. Like, all the emails in one inbox. I don't want that. If I have, say, two accounts, I want to quickly switch between Account 1 & Account 2 inboxes. I don't want one big inbox. I like to keep things separate.
Can you please implement this?
Photo of Sarah Poulin
Sarah Poulin
  • 3 Posts
  • 0 Reply Likes
Posted 5 years ago
  • 2
Photo of Paul - Technical Support
Paul - Technical Support, Employee
  • 11315 Posts
  • 530 Reply Likes
Hello Sarah, unfortunately favourite folders are not currently an existing feature in eM Client, however you can setup a number of custom smart/search folders.
Right click on your smart folders currently listed and select Display > Search folders. The same way by right clicking search folders you can create a new search folder.
Search folders allow you to create a custom search value, that will scan the selected folders/accounts or all your folders as well, and collect the messages that are found according to the search term into the virtual search folder. You can use this in most cases as a workaround for favourite folders.
Hope this helps,
Sarah Poulin
  • 3 Posts
  • 0 Reply Likes
Okay, that seemed to do the trick. Thanks for your help! My only complaint now is not being able to put them in the order I want. It forces alphabetical order.
  • 11315 Posts
  • 530 Reply Likes
Unfortunately changing the folder sort order is not currently possible, but we're considering improving this in future releases of eM Client.
Photo of The Merg
The Merg, Champion
  • 216 Posts
  • 36 Reply Likes
One thing you can do when using the Smart Folders Inbox is to customize the column view to include Account. Right-click on the column and select to "Show in Groups". If you then sort by Account, it will group messages by each account and within each account it will default to sorting the emails by date. It  will also give you the ability to expand/collapse each of your accounts.
HTH,
Merg
Photo of Grant Collingwood
Grant Collingwood
  • 35 Posts
  • 6 Reply Likes
I tried using the Search Folders option in Smart Folders, but they are Read Only, so you can't add emails to them. With Outlook Favourites, they are the same folder, like a link, and you can do everything to them just like the actual folder. It would be great to have something like that in emClient. Like me, you have can have a long list of folders, but only use 4 or 5 on a daily basis.
Grant.
Photo of Ross McWilliam
Ross McWilliam
  • 1 Post
  • 0 Reply Likes
Just wanted to bump the feature request for favourite folders as the smart folders are read only and don't show any unread message count.
Thanks, Ross.
Grant Collingwood
  • 35 Posts
  • 6 Reply Likes
So funny. I received an email from emClient today asking for money to provide lifetime updates. They really think, after failing to deliver this requirement for 5 years, they have the nerve to ask for more money ?
Photo of Gary Curtin
Gary Curtin
  • 9467 Posts
  • 1124 Reply Likes
Seems that after 4 years it is only in the past couple of weeks that this thread got it's first vote. ;-)
Grant, I think that this topic is discussed elsewhere where eM Client Inc. have said that they are considering it.
Gary Curtin
  • 9467 Posts
  • 1124 Reply Likes
Favorites folders are included in the upcoming version 8. ;-)
Photo of The Merg
The Merg, Champion
  • 216 Posts
  • 36 Reply Likes
But I bet that the favorites still won’t be locked at the top of the folder list when you start scrolling through your accounts/folders...
- Merg
