Every time I get a new mail notification , a pop up telling me “Roxio Cine” is trying to load and start but,it cannot . My mail loads ok but, this screen pop up is annoying. I don’t know what this Roxio thing is.
I am using GMail with sound notification turned on.
Any ideas what could be causing this, I never had this problem with Gmail.
Hi, unfortunately this is nothing our application would cause, I can only suggest to either open or uninstall the Roxio Cine application which is probably installed on your computer.
You can either try to change some notification settings or install the application if you’re not using it.
Thank you, let us know if you come across any issues or questions about eM client, we’ll be happy to help,
